DGTeam Firmware
14 Dec 2003
Edinburgh
Anyone able to email (in trust) the DGTeam firmware for a sky netgear DG834GT? I had a look around the web and could only find one place hosting it and just get the message "user is out of bandwidth".
Much appreciated.
Assuming you're still with BE, do a search for DGTeam in the forum. There are numerous links there for DGTeam firmware.
I found the Uber GT firmware to be a lot better than the GT team firmware - had problems with errors on the line and wireless. Uber Gt seems a lot more stable and my line syncs higher with less errors 18mb down and 1mb up - will try annex M soon
I've used both and found them both to be much of a muchness to be honest - probably depends on your line.
I use DGTeam now generally because it's the only one of the two that still gets updated :)
Latest version is apparently full of bugs
The version I'm using was dl'd/installed 2 or 3 months ago and is fine - has it been updated since?
That said, I know that a friend of mine had problems with this version on his DG834GT so perhaps it's luck of the draw.
edit: Just checked the site and yeah, I'm quite out of date :o
I'm with O2, on their Access package (BT Wholesale ADSL Max), is it be possible to change the (downstream) SN Margin (signal to noise ratio margin) on my line using the Netgear DG834GT with a modded firmware?
Yes..it's really easy. Using the DGTeam firmware you can set it in the 'advanced adsl settings' page. Just a slider for between 1% and 100%
I see there are Netgear DG834GT's distributed by Sky, will these modded firmwares work with them, if the Sky ones have been re-flashed with Netgear's own firmware?
You can set the target SNR without flashing any custom firmware - just the custom stuff allows you to save on reboot. Have a search on kitz adsl site
Yeah, you can do but why would you not use a more up to date firmware with bugfixes and avoid having to use the command line? Makes no sense...
The latest -835 seems more flaky than the previous version (which i have also tried), i simply added the info about the command line as maybe worth trying prior to flashing custom firmware :)
