- 3 Oct 2008
- South London
Good noon to you.
I'm torn whether this should go in enterprise solutions or networks but i'll try here first
I have a load of HP ML350 G4 and G4p servers. They have the HPNC7761 NICs in. I know they support VLAN tagging but what I need to know in order to make a network design decision is how this setup presents to the OS (Server 2003 Standard R2 SP2). Does the NIC just read the tag and ensure replies are tagged to go back onto the same vlan or is it a little more clever than that and does the OS see separate virtual adapters for each VLAN? (as with broadcom BACS) Just need someone that's done it before to say Yay or Nay.
For those that care why....
Situation is one VLAN is becoming two. I have servers that need to talk directly to both VLANs. One of which Provides a DHCP service. One of my primary concerns is whether it can still run DHCP for one of the VLANs but not the other using a single network card. In windows DHCP config I only know of ways to bind DHCP to a NIC not a VLAN. Hence if virtual adapters are created per VLAN setting this up is easy. Else perhaps not.
One that I'm cleaning up gradually.
