Diablo2 Help
7 Mar 2005
Wolverhampton
Hey there !
I've been joining games to kill baal minions to level my sorc up. Recently i killed Baal and started a game on Knightmare. Anyway, i haven't quiet completed Knightmare yet.
Everytime i now try join games to kill baal minions to level, my character is always on knightmare, if you get me? I mean i dont have WP to baal minions so cant level.
Is there not a way i can join games with the normal setting instead of always on knightmare? My gf was doing it last night she was saying something about i have to make a game and set it to normal, save then log. I dont know, she wont tell me how to do it !
Anyone here understand what im trying to do? Help plz !
Cheers.
When you start your own game, put in the name of the game.
At the bottom theres radio buttons to choose between normal, nightmare and hell. Hell should be greyed out.
Click normal, then click create game.
I can do that, but everytime i want to join other peoples games, its alwatys on KM :/
This is what i want to try change :(
Well actually its NM(Nightmare) ;)
You could make a new char and look on the game list, then join that game on your other char.
It shows you games based on your hardest unlocked difficulty. So youve got to nightmare, it shows you more nm games in the list. It's annoying if youre looking for normal games. If you want to do normal baalruns you'll have to look for "norm" in the title, or make your own.
To be honest, you might as well get to hell baal as quickly as possible and just level there, it's easier then faffing about in normal :)
^^ If you are level 40-45, just get on with NM TBH.
That will be more than enough to spam orb over anything that moves (if you are part of the 90% of sorcs with orb anyway) and win.
THere is no way to see normal games when you get to nightmare. The way around that is to start a new character, find a game naming system (IE BaalKill 4) then swap characters quickly and type the game name in. Alternatively you can make the game series yourself and teleport down to baal yourself.
I've been making my own game.
Im stuck on NM on Ancients Way, where you have to kill them 3 boss's without leaving the circle. I have lvl 22 orb, my sorc is lvl 67, i still get owned with my gfs lvl 67 druide helping me :(
Another problem i get, when i kill a boss, say diablo, the game freezes and my disk spins loads, then everything goes fast forward for 2 seconds to catch up ?
