Hi all,
My PC today decided to shut off mid-game. It just turned off like that, and cannot start again.
I am trying to diagnose what the problem might be. I can't even get it to post, so I assume it's some hardware fault. What I want to ask is - what can I do to narrow down to the GPU or CPU?
My system is:
Mobo: MSI B450 Tomahawk Max
CPU: AMD Ryzen 5 3600
GPU: MSI RTX 2070 Ventus
RAM: Corsair Vengeance LTX 3600Mhz
What I have ruled out:
- PSU - it tests successfully by itself using a jumper tester
- PSU cables - I have tried different ones (provided with the original PSU and have used the correct ones)
Things I've tried:
- Starting with just Mobo, RAM and CPU. Result: No signs of life (the mobo LEDs don't even light up)
- Starting with just Mobo (CPU disconnected). Result: Posts and fails CPU check so CPU LED is red
- Adding more components (GPU). Results: no signs of life
I'm not sure what troubleshooting procedure to use. I hear Ryzen don't have onboard graphics and might not POST without a GPU installed so I'm not sure how to test the CPU and GPU in isolation.
Any help would be appreciated.
Thanks.
My system is:
Things I've tried:
Thanks.
