Diagnostic help!
27 Nov 2002
Desborough,Kettering
My wife's pc has been running 2 months since I upgraded it, no issues and fine running games etc.
Left on overnight and today there's no display although it's still powered. It powers on, fans start but no sounds and no display.
It's an i7 4770, gigabyte motherboard and rx590, ssd and a second hdd. 4x4gb ddr sticks with leds, no lights on power on though. I cannot remember if that is usual or whether it only lit after windows started.
I reset cmos, no change
I have restarted several times, no display to either of 2 monitors using different gpu outputs.
I have removed the gpu, reset cmos and tried connecting monitors to on board graphics, no display.
Any idea of next steps? I was planning on removing memory and trying just pairs, then stripping down to minimum, if no change removing mobo and trying outside the case.
My chief concern is no sounds of attempted boot, it's near silent with a few fans turning on minimum speed. Does it look like a dead mobo? , I can't help thinking cpu should be fine, psu should be okay, cable's were unmoved and should be okay, mobo touching case and shorting is unlikely.
Frustrated.
Sleep was not enabled, biggest issue is power but no bios post.
Spent all day stripping it and no joy, bought a ryzen 5 barebones to replace it last thing today.
Might have to swap pcs with the wife tho, as I have a i7 4770 too.;)
Maybe worth trying this.
Pull the reset cable off the mother board.
See if the PC boots then.
I had a faulty reset switch which gave the same problems.
