Diagnostic Utilities?
1 Dec 2003
Oxfordshire UK
Just had a random hardware failure crash acording to windows. Plugged in my iPod and it BSD'd with a high pitch squeal, but nothing odd in the crash report.
Are there any utils out there I can run to test things such as CPU, Mobo, Ram etc?
Only a little concerned as the system is only 8 months old.
AMD 64/3700+ @ stock
2 x 1GB COrsair XMS Cas 2 Ram DDR400
MSI K8N Neo4 Platinum nForce4 Ultra Mobo
Audgiy 2 Plat ZS
Leadtek 7800GTX
Temps:
CPU @ 45
System @ 33
GPU @ 58
Was running Firefox, iTunes & Msn
Prime95 to test the CPU - run Torture test "In place large FFTs" for at least 8 hours
memtest86 to test the RAM run test 5 for a minimum of 15 passes, or run all tests overnight
