Basically wàs playing Mafia 2 on all high settings with forced aa using nvida inspector. Played for about 15mins then all of a sudden my PC just switched off. No blowing up sound nothing like that but just switched off. Now it wont switch on again
Although my external hdd lights up when plugged in to USB port then switches off after 15seconds.
My specs:
i5 2500k
Foxconn h67 it's
4gb ddr3
Windows 7 64bit
Silverstone sugo sg05 with supplied 450watt psu
Gtx 465 unlocked to gtx 470 and overclocked to 815core and 920memory
I had my gpu fan on 100percent and I am quite sure my overclock was stable.
Anyways did my psu blow up? Or is eyerything basically ruined? Wat should I do? Please advise. Using my phone to post so pardon any spelling mistakes
My specs:
i5 2500k
Foxconn h67 it's
4gb ddr3
Windows 7 64bit
