did I choose a worthy card for my setup ?
20 Sep 2011
I have got a asus pb278q 2560 x 1440 monitor
and the g card which was bought 2 weeks ago
evga gtx 680 4gb, do you think that is good for my res? does the 4gb make a good difference?
let me know your opinions
A 680 is a good card for a single monitor setup. It will power through all the current games with your monitor no problem. 4GB of RAM on your card is plenty. :)
Considering you could have got a 780 for a little more I'd say you did a mistake.
the classified was a week only deal from overclockers for £359
I had the chance to get a new 780 for £470 delivered msi TF but i opted out
but most 780s are 500 upwards which isnt close to the price I paid for the classy
the classified was a week only deal from overclockers for £359 with splinter cell & metro last light
Well that's not too bad then as the 2gb 680's are going for that.
The 4GB wont make a blind bit of difference, the limiting factor of those cards when upping the res is the smaller bus size, and even then it's not untill you start getting past 4m+ pixels does it really show its weakness.
Play some games on your setup, you should be able to play games with decent settings @playable FPS no probs.
what was the reason for the 4gb versions if they provide no gain on the 2gb?
