Did i damage anything ?
8 Nov 2018
Hey guys
I'm running a 8700k @stock + MSI z370 gaming pro carbon ac + corsair vengeance LPX 2X8 3000mhz CAS15
First of all i tried running XMP which lead me to OC failed....
So i used the MSI feature memory try it which give me 2666mhz cas 13 15 15 @1.35V every other voltage in auto mode. I could use my pc and gaming with these settings for 2-3 weeks maximum before starting having BSOD i tried change timings to 16-18-18-35 @1.2 no boot, 1.25 unstable 1.3 unstable and 1.35 no boot :O.
Basically i'm using my ram at 2400mhz cas 14 and it runs fine (memtest confirm) but it's not what I want .....
My question is did i damage my cpu's IMC by using this ram profil (2666mhz cas 13) cause it seems that is very tight timings and it could have overstressed the imc .....
Or is this motherboard ? cause if I try using one stick at a time on slot 2 i can reach 3.000mhz on both stick but if I put those 2 stick still one at a time on slot 4 it does boot but it's not possible to reach 3.000mhz with xmp enabled while it was possible on slot 2.
Thanks in advance for your answers.
I heard on msi's board that when you oc your ram, the vccsa and vccio voltages are very high ~1.4. Maybe this is what happened on mine and degrade my imc in few weeks ... what do you think ?
