I just had the weirdest problem with my main rig... (AMD64-3.4Ghz, 512Mb DDR, XP Home SP2, Avast, Spybot, Adaware2007).
I was happily browsing the web (Firefox 2.0.0.11) and listening to music (winamp v5.51) when suddenly Firefox took 160Mb of RAM and 100% of the CPU... I Ended the Process and 'explorer.exe; did the same and just hung!!!...
I rebooted my Machine and after the Memtest etc.. screen I got "Error loading Operating System" on screen
I re-booted, and got the same!..
Weird thing is I've got a Dual-Boot with Ubuntu (Linux) 7.10 and it didn't even get to the Grub/Boot options..
So I turned it off and stormed off in a huff!!
I came back later resigned to the fact I might need to re-install Windows, turned it on... et-voila it booted fine into windows!!..
Thinking I might have a problem I came on here and found http://forums.overclockers.co.uk/showthread.php?t=17827636&highlight=virus considering I might have contracted this or similar.. I fixed my MBR and it all seems to be hunky dory!!.. (Lost my Linux install/Grub.. but thats no biggie).
I've run every concevable test (with the software I have to hand) AV/Spy/Trojan and found nowt!!..
So this leads me to believe... the system is either over heating, I had a virus or My Hard Drive(s)/IDE Channel (mobo) are failing.
Does anyone have any suggestions on further tests I can perform???..
Cheers
Sim.
Cheers
Sim.
