Hi,
Corsair have listened when people have asked for the ML fan to become an RGB model. The Fan comes in both the 120mm and 140mm so you have the normal options available to you. The ML Fans have been a great success so it is no wonder they decided to add the current market trend to the fan.
The Corsair ML120 PRO RGB PWM fan combines unrivalled performance and low noise operation with vibrant RGB lighting controlled in Corsair Link software. By utilizing ultra-low friction magnetic levitation bearing technology, ML120 PRO RGB can deliver more airflow and higher static pressure at lower noise levels than traditional bearing fans, backed by a long-life five-year warranty. Four independent hub-mounted RGB LEDs output a vivid blast of light and colour, making it easy to match your system’s style, and with a 400 RPM to 1,600 RPM control range, it’s easy to equip your PC with quiet cooling, in any colour.
Corsair ML120 Pro RGB 120mm Premium Magnetic Levitation PWM Fan @ £24.95 inc VAT https://www.overclockers.co.uk/cors...um-magnetic-levitation-pwm-fan-fg-06f-cs.html
The ML120 PRO RGB PWM Fan combines unrivaled performance and low noise operation by utilizing magnetic levitation bearing technology with vibrant RGB lighting controlled in CORSAIR LINK sofware
Only £24.95 inc VAT.
ORDER NOW
Corsair ML120 Pro RGB 120mm Premium Magnetic Levitation Fan with Lighting Node - 3 Fan Pack @ £89.99 inc VAT https://www.overclockers.co.uk/cors...-with-lighting-node-3-fan-pack-fg-06g-cs.html
Only £89.99 inc VAT.
ORDER NOW
Corsair ML140 Pro RGB 140mm Premium Magnetic Levitation Fan @ £29.99 inc VAT https://www.overclockers.co.uk/cors...remium-magnetic-levitation-fan-fg-06j-cs.html
The ML140 PRO RGB PWM Fan combines unrivaled performance and low noise operation by utilizing magnetic levitation bearing technology with vibrant RGB lighting controlled in CORSAIR LINK sofware
Only £29.99 inc VAT.
ORDER NOW
Corsair ML140 Pro RGB 140mm Premium Magnetic Levitation Fan with Lighting Node - 2 Fan Pack @ £74.99 inc VAT https://www.overclockers.co.uk/cors...-with-lighting-node-2-fan-pack-fg-06h-cs.html
Only £74.99 inc VAT.
ORDER NOW
ALL CORSAIR FANS AVAILABLE HERE
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
