- 16 Mar 2016
- Rubber Dinghy Rapids Broo
Since I have a thermaltake core p3 snow case, I wanted to get a white or black/white set of cables, and after seeing how expensive they are I figured that I could just get a white psu which comes with white cables already and the corsair RMX models look the most affordable with a 10 year warranty, but there appears to be 2 variants of the same RMX models and the only difference I can see is an increase in depth of 20MM and a £20 increase in price.
750w
CP-9020187-UK £115 160mm depth
CP-9020155-UK £135 180mm depth
850W
CP-9020188-UK £130 160mm depth
CP-9020156-UK £150 180mm depth
Is it worth going for the larger dimensioned PSU, or is the smaller one a newer model which has been shrunk down. Is there any noticeable difference in operation?
Are there any other white PSU's that I should consider?
750w
850W
