i kno competors not allow so rough prices im going to build a rad box for my comp so no worrys about space. my spec in sig i have sli gtx with amd duel 4400dfi mobo. My buget is bout £300
anyway.. I think you were close before, you have the storm cpu block so I would suggest.
dual heatercore or any random 120.2 rad, 120.3 really isn't neccessary and will just increase fan noise
swiftech mcp655 pump
dangerden maze 4 low profile sli kit
5.25" bayres
4 meters (way too much) xspc tubing (very close to tygon, I use it and its only 2.99 a meter! cheap enough to have enough to not worry too much about cocking some lengths up mid install)
swiftech mcw30 chipset block (optional, save yourself about £15 by getting a zalman NB block)
2 half decent 120mm fans
now I got that lot down to £240 delivered (including swiftech NB block), thats with half of it coming from the states. You'd have to get some barbs and ptfe and hoseclips etc but you really shouldn't be over £10 for that lot.
Actually I won't mail you, just noticed you don't have your mail in your profile. Drop me a mail (in trust) or catch me on msn and I'll point you in the right direction.
