difference between 120 and 250gb ps3 slim
14 Dec 2005
any other difference apart from the hdd size ?
I have a 500gb in my old style ps3 I intend to use
i take it the hdd spec is the same in the slim as the original ? 5400rpm notebook size?
it's not some low heat generating hard drive or anything they use now ?
My feeling would be to wait for August if they release the newer 160 and 320GB PS3s over here, these will more than likely use the 40nM GPu/Cell.
so the 120 and 250gb slims run cooler than the old ones, but the newer ones will be even better ?
I might not be able to wait that long, my ps3 is on its last legs I think!
If the failure of your old PS3 is an issue i wouldn't wait around for a manufacturing process revision, to the normal end user the difference between the current slim and the 'new' one coming in August would be unnoticeable.
