28 Sep 2006 at 11:19 #1 Voltage Voltage Soldato Joined 5 Jul 2006 Posts 3,647 I dont understand DDR2 to well. Whats the difference between 5400 ddr2 and 6400 ddr2? overclockability? at stock do they run the same?
28 Sep 2006 at 11:31 #2 wizardmaxx wizardmaxx Associate Joined 21 Aug 2006 Posts 1,908 Location Stafford Diff is 667mhz and 800mhz, depending of timing u can have 667 that is faster than 800
28 Sep 2006 at 12:43 #3 Voltage Voltage Soldato OP Joined 5 Jul 2006 Posts 3,647 so if i was to have a stock Conroe whats the best ram?
28 Sep 2006 at 22:44 #4 Buffalo2102 Buffalo2102 Associate Joined 9 Jun 2004 Posts 1,543 Depends which conroe and whether you want to overclock or not.
29 Sep 2006 at 03:16 #5 doodah doodah Caporegime Joined 18 Oct 2002 Posts 28,994 Location London This should give you an insight.
