Difference Between a Storm and RBX
27 Jan 2003
Chesterfield, UK
Hi,
Trying to get old of a Storm G4 but have been recommended a DD RBX. Can't seem to get the Storms anywhere. Anyone know the real world differences?
Difference in price is about £20.
Will be used with a ThermoChill PA120.3 and Laing D5
The storm is a very aggressive and restrictive block for serious cooling (would be great in your setup), wheras the RBX is more of a standard block (3 barb config too, eugh). The current available block which is almost as impressive as the storm (well, first impressions) is the AquaXtreme MP-05 SP Limited Edition. I had mine delivered yesterday (awaiting other parts for new loop) and it is flippin gorgeous :)
weescott said:
The RBX is old technology. Have a look for the Apogee or AquaXtreme, Nexxos...all perform better.
Will they perform better than the storm in my setup because i wil replace the storm block i got otherwise for the setup i want to get eventually
as we are on the subject of water blocks.. how good is the DD TDX ? I am a complete WC noob so don't laugh at me if this is a pile of poo or not :-)
FYI i read a thread over at XS said that the Apogee performs worse than a TDX
:eek:
1. Swifteh Storm - 75USD - this is the top performing waterblock currently in retail. It is better suited to more powerful pumps, but still performs well with low flow/power pumps. Apparently the Storm is no longer dsicontinued, but it seems there are now large price hikes, and somewhat limited availability.
Due to repeated incidents in which the storm is improperly installed, please be advised that the proper way to install the tubing on the storm is as follows: inlet in the center and outlet towards the outer edge.
2. Swiftech MCW6002/6000 - 45USD - for low power/flow pumps these waterblocks are top performers.. with moderate restriction these waterblocks matched with low power pumps will net decent flow to allow usage of a second waterblock
3. Cooltechnica MP-05 - 50-65USD - a high restriction waterblock with excelent performance. while it does not outperform the Storm per pump power, its lower pricetag makes it an attractive choice.
4. Danger Den TDX - 52USD - while a good waterblock, it is not an optimum choice of waterblock for a high or low power pump system. I list it merely for completeness of the guide.
5. Danger Den RBX - 52USD - Again, a good waterblock, but not worth considering unless you have some desire for a 3 barb waterblock.
6. WhiteWater LE (all coper version) - 44USD - Origionaly designed by Cathar, this 3 barb waterblock performs well, but uses a dated design and is not optimal for maximum performance.
7. Swiftech Apogee - 45USD - The newest block from Swiftech that takes a step backwards in performance. It is essentially a MCW5000 respun with a new manufacturing process (cheaper), and new delrin top. While Swiftech says its the best thing since sliced bread and Television, please try to avoid it as EVERY other block on this list performs superior to the Apogee
Townlea said:
Is that bad or good? lol remember I am a noob ;) be friendly
EDIT ahh you added a list :)
He trying to say that swiftech said there new waterblock was ment to be as good as the storm if not better but people saying it one of the worst
I got the storm and im going to keep it paid £50 look like i did the right thing at the time even tho i havent got a w/c setup
