Difference between Abit IP35 and IP35 pro ???
14 May 2007
London
..other than the pro being £40 odd more ???
I see that the pro has eSATA. I need the firewire and it has that too. YOu guys reckon the bog standard IP35 will run the Q6600 ???
Cheers,
Steve
doh....
maybe I should read the thread posted a day earlier ....
sorry for wasting your bandwdith.
The Consensus is that there is **** all info on the bog stadard board out there..... :mad:
Steve
The standard board will run a Q6600 fine - other than the changes necessary for the different features there really isn't too much difference in design.
kirkster said:
doh....
Steve
There is a review of the vanilla IP35 and even the IP35-E. They are both on the same site but can't remember the name. I was intrested in the board a while back too. It should take a bout 5mins on google.
Btw iirc the IP35-E and IP35 are essentially the same. The "E" just has a few features missing. They are however different to the pro (diff layout etc) so don't expect them to overclock the same
