5 Jul 2011 at 18:58 #1 ebis ebis Associate Joined 12 Nov 2010 Posts 42 Hi, I curentlly have my core voltage set to 1.248 but by PLL voltage is left on auto and it's up at 1.94. Should I also be setting this manually?
5 Jul 2011 at 19:55 #2 koooowweeee koooowweeee Soldato Joined 13 Jan 2010 Posts 6,356 Location Manchester you dont have to. leave it on auto.
5 Jul 2011 at 20:25 #3 twist3d0n3 twist3d0n3 Soldato Joined 3 Aug 2008 Posts 10,477 Location Bath, England what chip is it? i wouldn't ever run a PLL that high :/
5 Jul 2011 at 22:09 #4 koooowweeee koooowweeee Soldato Joined 13 Jan 2010 Posts 6,356 Location Manchester i think its a sandy. mine is that high on auto
5 Jul 2011 at 23:46 #5 twist3d0n3 twist3d0n3 Soldato Joined 3 Aug 2008 Posts 10,477 Location Bath, England good luck having that last any length of time then
6 Jul 2011 at 00:24 #6 ebis ebis Associate OP Joined 12 Nov 2010 Posts 42 yeah it's a 2500k, so will lowering it do anything negative, I mean there must be a reason why it goes so high right?
6 Jul 2011 at 00:55 #7 Bos Bos Associate Joined 4 Apr 2011 Posts 161 Location Derbyshire Always thought CPU PLL - Auto was 1.8v on all SB motherboards? It was on both the Asus boards I've used. I messed about with it a while ago to see if lowering it caused instability. Had it set to 1.5v ever since without a single problem. If you look at various places about Sandy Bridge overclocking it recommends never to go above 1.9v for CPU PLL Last edited: 6 Jul 2011
