- 25 Sep 2005
anyone know what the difference is?? heres some info i've found:
The MAZE5-GPU is designed to significantly improve
the cooling over the former MAZE4-GPU Product!
It is also designed with the award winning Delrin/Acetal
top providing a light weight & anti-corrosive solution.
Features:
* Over 100% increased Surface Area for significantly improved heat transfer
* Machine Lapped and Polished
* Choice of fitting size
* Complete block weighs about 6oz (171 grams)
* Non-Corrosive design
* Delrin/Acetal Top chamber allows full use of channels with minimal flow loss.
* Pressure tested before shipment.
Compatibility NVIDIA:
* 7900GT, GTX and GS series (Series 2 Hold Down Style)
* 7800GT, GTX, 6800 Series, 59XX Series (Series 2 Hold Down Style)
* Older cards or cards with 2 hole mount system (Uses Series 1 Hold Down Style)
Compatibility ATI:
* X1900, X1800, X1600 with 4 Hole Mount System (Series 2 Hold Down Style)
* Compatibility ATI: Most Radeon Series blocks (9500, 9600, 9800, and X800 series) with the two hole mounted fans (Series 1 Hold Down Style).
* Excludes the All-In-Wonders before the X1900 Series,
Includes:
* Complete Block assembled with Top and Fittings.
* High Flow G 1/4 1/2" or 3/8" OD Fittings
* Low flow restriction low pressure drop
* Stainless Steel Hold Down
* Please leak test 24hrs upon receipt.
* Verify secure mount 48hrs after installation.
Features:
Compatibility ATI:
Includes:
