Difference between FS L22W-5, -6SA, -7SD
18 Mar 2003
All three have the same basic specs:
473.76 x 296.1 mm
1000:1
300cd/m^2
170'/160'
1 x Analogue
The only difference I can find is that the -5 has a different stand.
What is the numbering system here? Is it just a revision with no change in specs? Does it indicate a better panel? Is it the higher the number the newer the product?
There is a price difference of about £10-20-30 between the three. I can't work out why.
Word doc's on the range here:
http://www.fujitsu-siemens.co.uk/rl/servicesupport/techsupport/monitors/Con-Displays/Con-Index.htm
