12 Nov 2007 at 14:01 #1 DJMK4 DJMK4 Soldato Joined 1 Dec 2004 Posts 22,902 Location S.Wales Im looking to upgrade a notebook with more ram, but the cam currently in the laptop is listed as "PC2-4200S" Is there any difference or can i just stick some PC2-4200 ram in there?
12 Nov 2007 at 14:24 #2 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 32,717 Location Rutland What laptop is it?
12 Nov 2007 at 14:25 #3 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,468 Location Antrim town You'll need SODIMMs. Standard DIMMs usually won't fit.
12 Nov 2007 at 14:27 #4 DJMK4 DJMK4 Soldato OP Joined 1 Dec 2004 Posts 22,902 Location S.Wales Cob said: You'll need SODIMMs. Standard DIMMs usually won't fit. Click to expand... I know this, but usually SODIMMS are usually listed as (PC2-4200 SODIMM), and not PC2-4200S. Just wanted to clarify. Its a Fujitsu Siemans Amilo
12 Nov 2007 at 14:36 #5 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,468 Location Antrim town Which Amilo? A quick glance around the net would suggest that it takes SODIMMS.
12 Nov 2007 at 15:03 #6 DJMK4 DJMK4 Soldato OP Joined 1 Dec 2004 Posts 22,902 Location S.Wales Cob said: Which Amilo? A quick glance around the net would suggest that it takes SODIMMS. Click to expand... OK iv odered SODIMMS.
