After a bit of advice please, I am going to buy some more RAM, total 32gigs
The PC this will go in is to be used for 3D art [VUE, POSER] and video converting, Ie7 sandybridge CPU
Is there much difference between these
Thanks for any help
Corsair Vengeance Low Profile 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (CML16GX3M2A1600C10) [CML16GX3M2A1600C10]
Vengeance LP Performance Memory modules, 16GB (2x8GB) DDR3 1600MHz CL10 Unbuffered DIMM Memory with XMP 1.3 for AMD, Intel Processor platforms, including 2nd and 3rd generation Intel Core i7 and i5 systems. Every Vengeance memory module provides users with outstanding performance and high quality. Vengeance memory modules are built using carefully selected DRAM to allow excellent overclocking performance and rock solid stability.
Features
- 8GB Modules
- Each twin module set is tested at 1600MHz
- Vengeance LP heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 10-10-10-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 10-10-10-27 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Two matched 8GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge/Ivybridge compatible
Corsair XMS3 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (CMX16GX3M2A1600C11) [CMX16GX3M2A1600C11]
This 16GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 11-11-11-28. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 16GB memory kit (2 x 8GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 11-11-11-28 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Thanks for any help
Features
- 8GB Modules
- Lifetime Warranty
- 1600MHz
- XMS Heat Spreader
