Difference between satas
10 Dec 2012
leicester
Hi their i wanted to know the difference between sata 2 and 3,what should be plugged into what i.e. optical drive,ssd,hdd
thanks
josh
Everything should be compatible with everything else, so in one sense it doesn't matter what gets connected to where.
In practice though, you should make sure that your SSD is connected via sata3. HDDs and optical drives won't come close to using all of the bandwidth in sata2, so they can go anywhere.
