Hello all, after a little advice on monitoring the cpu temp. I have an ABIT IP35 Pro XE m/b which has uGuru monitoring and overclocking facility. When monitoring the cpu temp using uGuru, the temp shown is around 10 - 15 degrees higher than that of Core Temp. Which one is going to be the most accurate?
. System now idles at 28 degrees C in a pretty warm room.
