Difference between these 2 Corsair PSU's
11 Aug 2006
Yes, I will be RMA'ing the Enermax. I always thought they were one of the best brands since my old Noisetaker 600W but did suspect something odd since OcUK doesn't seem to stock Enermax PSU's anymore.
Thanks.
Thanks.
They are still good PSU's, just because OcUK doesn't stock something doesn't mean they are rubbish.
The Seasonic range is a new entry and they are and have been considered the best for ages.
Enermax are still a top psu maker. Got a 600w noisetaker still nice and quiet after 8 years almost constant use.
Enermax still holds its ground. And they design their own PSUs so props to them.
Seasonic (SS-1000XP review) is the daddy's. They design internals for Corsair, Antec, and XFX PSUs as well.
the AX1200i is a brand new design. It has less PCIE cables than its predecessor, but unless you do quad-sli, no worries.
