difference between these 55 hdr sonys
17 Jan 2006
NW
KD55XD8599
KD55X8509C
looking at the specs on websites im struggling to tell the difference except the £300 difference.
thanks
The KD-55XD9305 is the all singing and dancing top of the range version and has these which the other does not:
X-tended Dynamic Range PRO, Slim Backlight Drive
2160/50p, 2160/60p
More speakers/power
There will be some others
http://www.sony.co.uk/electronics/t...T-CAT-TV-CAT-EN_GL-2015-11-M02-HOTNEW-XD94-93
Here is the KD55XD8599:
http://www.sony.co.uk/electronics/t...TOUT-CAT-TV-CAT-EN_GL-2015-11-M02-HOTNEW-XD85
It really does have an exceptional picture and the is designed for all HDR sources with the highest quality. 2160/50p/60p gives you the ability to handle all UHD streams. This one will display the maximum resolution of Sky Q UHD. If you want the best picture and compatibility and some future proofing then this is the one to take.
The 65X8509 has a 10Bit panel and can do HRD 60\50\24 and it's backlit.
It also can do UHD and REAL 4K :) and it's cheap now.
