Difference between these cables?
One is 165mm and the other is 150mm.
Apart from that and as you pointed out, the name.
they do look the similar.
I did look for length difference. Obviously not hard enough.
10mm/1cm isn't anywhere near enough to warrant the price difference, though. I'll go with the akasa, it only has to be long enough to go through the grommet right beside the header.
