- 14 Oct 2007
- newcastle
What is the difference between the Difference between X470 TAICHI ULTIMATE and X470 TAICHI? Is the ultimate a considerably better board?
they are TRUE 12 PHASES... doublers simply connect two phases from PWM Controller, BECAUSE the PWM controllers can only HANDLE a MAX of 8 PHASES only, some are less!!!
example of this z390 Aorus Xtreme and MSI Godlike. Both have Fully digital 16 TDA21462 60A powerstage's, 2 of these are linked to one IR35201 (total of 8 of them) liked to IR PWM 8 channel controller.
So in either cases of the Aorus Xtreme, MSI Godlike and the Taichi, none of these should really have much issue running any current or planned future CPU release with however many cores and at whatever speed the cores can overclock to?
The summary is that it is most likely a 6+2+1+1 “virtual” configuration of VCore + VCCGT (iGPU) + VCCSA + VCCIO, 3+2+1+1 “actual”.
To even call it “6 phases” at all for the VCore is slightly misleading given there are no doublers at play but it really depends on how flexible the definition of a phase is.
Thanks @orbitalwalsh, looks like the Taichi wont have any bother at all running the alleged 5.1ghz 3850x with some all core overclock then
x570 boards are slightly better then z390 boards, all I'll say on that matter
but yeah, if your going to push flagship ryzen 3000 then you'd only want the flagship board from each of the vendors - and maybe a mono block if ou've got the cash. Aorus 7 had the best heatsink on it , rest just aluminum blocks
That's very interesting. I'm holding off for X570 for PCIE 4.0. Hopefully that'll future proof me for a little longer than an X470 board.
X470 can be updAted to run PCIe 4.. but not sure what happens to other lanes and their bandwidth
Can. Doesn't mean they will. PCI-E 4.0 is going to be a big selling point for X570, not sure how much effort board makers will put into pushing PCI-E 4.0 on previous gen models...
interesting reads how PCIe 4.0 effects Infinity Fabric . based on Rome released data , could spell a nice boost for those with 1700/2700 not wanting a new chip but could squeeze out some performance going b550/x570
