DIFFERENCE BETWEEN
13 Nov 2002
ALFRETON ,DERBYSHIRE
hi can anybody tell me what the difference in speed will be between :
AMD Athlon 64 X2 Dual Core 5200+ 2.60GHz (Socket AM2) - OEM (CP-177-AM)
and
AMD Athlon 64 X2 Dual Core FX62 2.80GHz (Socket AM2) - Retail (CP-173-AM)
many thanks paul
If you're overclocking them there won't be much difference, they'll both overclock to about the same speed.
the FX multis will be unlocked up and down whereas the normal x2 will only be unlocked down
