difference in temps ?
19 Feb 2008
Home
will i see much of a difference in temp's once i go from a 2.4 duo to a 2.4 quad ?
im watercooling and my idle temp's are as follow...
i will be overclocking it to around 3.2ghz.
i have a q6600 on air @ 3.3Ghz (367 * 9) and my idle is @ between 21 and 30*C,
arctic 7 pro cpu cooler, antec 900 - rather loud
on prime95 stress for 16 hrs temp didnt go over 55*C 100% Load
it all depend s on voltage but if it stays at stock voltage you shouldnt see much of a difference at all maybe just a couple of degrees
edit - ive just noticed isnt the tjmax of that chip 100c not 85
