difference lian li PC60 & PC7 ?
28 Sep 2003
London
as title, apart from one beign in stock and one not.
what are the real differences between these two ?
and are they both ok for 8800 gtx ?
The PC60 holds 5 harddrives in the harddrive bay, and has 3 floppy drive bays where you could put more harddrives.
The PC7 only has a 3 drive harddrive bay and 2 floppy drive bays iirc. (Not got one of those to hand)
The PC60 also has a motherboard tray which is really nice :)
the Pc60 has 80mm fans, but the PC7+ has 120mm fans. I think the PC60 also has one more HDD bay.
does that make much difference.? the fans?
looking to overclock 6600 with thermalright ultra 120 extreme
and use 8800 gtx
would that case work ok ?
I've just landed myself a new PC7 SEIII and I have to say it's come on quite a long way since the PC60. For starters you have a proper removable HD caddy system in operation now, with rubber isolators. You get intake/exhaust 120mm quiet fans AND a 120mm VGA exhaust. They've finally ditched the noisy Adda fans. You also get a PSU mesh on the top panel for extra airflow. It's not bad at all for the money. One of the best value aluminium cases I have used.
I've got the PC 60B Plus II which is different to the PC60.
It has 4 fans in total, including 120mm intake and side fan. Also air duct (bit pointless) and removable motherboard tray which I have found very useful.
interested to know that aswell, at the moment, only the pc60 instock. would probablly prefer pc7
i think i found it, but its a bit more than the normal pc7.. would you say its worth the extra...
infact, take price aside, is it better than the pc60 as an overall case?
120mm side fan
Improved HDD caddy which can be rotated 90 deg and removed/installed with HDD's in place
140 mm square vent above PSU
3 very quiet 120 mm fans - at least mine are - 'Misty'
Around £15 extra - I bought one
Edit: I bought a black one which is reflected in the extra cost I referred to - the silver tends to be cheaper than the black.
Yeah I think it's worth the extra. I've got the silver one. It's currently running quietly, motherboard at a little under 40 degrees and the cpu (Q6600 @ 2.88ghz) at 40 degrees, and that's after an hour of gaming. I've got the intake fan and side vent running, plus the exhaust from the psu. It's a very solid case for the money.
shame ocuk dont have them.
they only have the older model and that is out of stock
edit:
seems the black SEiii is out of stock too everywhere
Does the pc7 seIII come with dust filters on the front and side?
With the larger capacity hdd bay will an 8800GTS/X type card fit?
Found them instock at £75 inc VAT!
The front fan has a filter but not the side although you could very easily cut one to fit.
You can rotate the HDD caddy 90 deg which gives more clearance but can't give you a definite answer on that.
