Jay123 said:Whats the difference???
Thanks
Azza said:You dont really need to know the difference do you?
You just need to know that the 8600 is a poor card and the 8800 is a supreme card compared to it and any other card in fact at the moment.
If your thinking of buying a 8600 you need you head testing in my opinion.
What he said.Azza said:the 8600 is a poor card and the 8800 is a supreme card
Cartho said:The 8600 GTS is not even up to beating an X1950 PRO or a 7950 GT in games like FEAR etc...
Anti Aliasing seems to kill it in a particularly heavy way, perhaps it is the limited number of shader processors? The smaller memory bus?
Or just the generally lower bandwidth available... It only has 32 GB/s of bandwidth - considerably less even than a 7900 GT!
In fact, according to the Guru 3D review (which I trust) it is not really that much better than a 7600 GT!
willhub said:My X800XTPE had 36.8 GB/s badwidth![]()
Cartho said:bus?
"Run" being completely subjective in this case.snowdog said:I can still run anything.
Like I said, completely subjective. Thank you for agreeing with me.snowdog said:Not everyone needs their games maxed out or has a 24'' WS .
james.miller said:you must run on very low settings then. my gtx still takes a conciderable hit with everything ramped up![]()
DJKahuna said:(FEARCombat: I can play that at full settings at 1280x1024 with 16xAF and 4xAA, and it's still smooth).
