Differences between dBi antenna strengths?
25 Sep 2011
Staffordshire, UK
I have a Huawei E3372h-153 4G USB dongle.
I believe it uses CRC9 connectors for the external antenna connections.
When searching for "CRC9 4G antenna" on eBay, results seem to show 12dBi, 2.5dBi, 5dBi etc.
When looking for an external antenna, which dBi should I be looking for?
What's the differences?
Certainly in patch antennas higher dB usually means higher gain and a tighter 'beam' pattern, so longer range but receives over a smaller target area.
If you know where the cell mast is and are comfortable aiming the antenna precisely then go for higher gain.
Also placing the antenna inside the car will cause issues with reflections and blocking. It would ideal to have the antenna outside the car.
It will lower your range. But most mobile phones have terrible range anyway with a tiny internal antenna. You will probably get something similar to a mobile. As a worse case you can always stick the antenna to the window when in the car with a suction cup.
Thank you a lot for your help!
I would recommend using a signal monitor app and playing with the orientation of the antenna to work out if it works best horizontally or vertically. I did a quick google but couldn't find anything quickly on UMTS polarization.
If you are going to be roaming around then whilst a higher gain antenna seems common sense it's actually not.
Like anything there is no such thing as a free lunch, a "true" 0 gain omni antenna will propagate in a full sphere, once you begin to add gain to your antenna you effectively start taking chunks out of your receive coverage area (horizontal or vertical or both). so whilst a 10dB antenna sounds so much better, that 10dB is only stronger in a % area of what an omni receives in.
The best analogy I can think of is the light output pattern of a bulb on its own (full spherical) to that of a lighthouse (tighter ray but stronger where it does go).
So whilst your antenna if pointing in the right direction can potentially give significantly better signal, if it's in the wrong direction will give significantly worse performance than a built in omni.
