Differences between DS3 revs?
31 Mar 2006
Thinking of buying a used one to replace mine which popped, mine was a rev 2... Anyone know where I can find what the main differences are between revs, in the real world? I can find stats, but nothing that actually, well, means anything to me :)
Cheers
Dont think there is any real-world difference. But the rev 3.3 natively supports 1333mhz fsb cpus, which could be useful for the next gen of processors from Intel. Thats a big could by the way.
Have a look on Gigabytes website, it allows you to compare mobos. As pointed out above the main diff between the rev2 and rev3.3 is official support for 1333MHz.
Nymins said:
Is it not only the DS3P that has firewire? The DS3 rev3.3 doesn't have it and i dont think the rev 1.0, 1.3 or 2.0 have it.
Yes youre right, it was the ds3p i was thinking of
