Differences between Intel 1155 chipsets
Basically, if you're overclocking you'll want a Z77 mobo. IMHO it is not really worth going from Z68 to Z77- I doubt you'd notice any difference at all.
If you were on an older chipset then maybe an upgrade would have been viable, but I'd stick with the Z68...
Ya I was looking at specs, while they may be better on Z77, it was the actual noticeable difference that I really wanted to know. If I more than likely won't see one then I'll spend my $$$ on another part
Cool, Thanks
