Differences between these 2 Nike AirForce 1 Trainers?
22 Nov 2002
Liverpool
Hi, I was hoping someone could advise. I was going to buy some Nike Air Force1 Trainers. I've not had Nike trainers before but pretty set on 2 that I have seen that appear very similar, but only a small difference in price. I was hoping someone could tell me what the main differences are, as such? From what I can tell, one says it has a lightweight midsole with air unit and the other says foam midsole with air unit. Because they look so similar, I was wanting to know, is one a better trainer than the other to buy?
The 2 are from the following links:
https://www.jdsports.co.uk/.../white-nike-air.../19575420/#!
https://www.jdsports.co.uk/.../white-nike-air.../19471848/#!
Thanks
James
Looks to me like the one that says "low" doesn't come up as far at the front? But I wear deeply uncool cheap trainers so take that with a pinch of salt
Having owned five or six pairs of air force ones I'd be surprised if there's much difference in the comfort.
One says JD exclusive so that's likely why the design tweaks. I prefer the first link as it has what I see as the correct, or at least more common tongue logo.
I'd also be checking something like blue light discount if it's available.
You can literally see the differences, you don't need us to tell you, unless you have bad eyesight
1st by link and 2nd in minusorange picture is nicer imo. Better proportion of black accents and the tick doesn't look like it was drawn on with a sharpie, it's more 3d too.
Mmmmmmm, white trainers. You'll like a right gangsta on the estate.
Shaquoia will be totes in to you. Use protection tho, you don't wanna become dad number 8.
