Differences between these PWM splitters?
18 Oct 2002
Kent
The differences this one and this one are fairly obvious - the first one is braided but only supports two fans compared to the 3 of the cheaper ugly one.
But what about this one? Not only is it cheaper the other two it's also braided and supports 5 fans.
I imagine i must be missing something here, but what?
Thanks
No its just the other 2 are overpriced.
To be fair that is crazy cheap though .. Its like 8 quid on a well known forest themed shop.
That Akasa FLEXA looks like a fantastic product. I have the standard akasa, (ugly unbraided one), both theese have the benefit of using a molex connector. This way your not overloading the boards cpu fan header, something that could be possible with the first braided cable linked. However, i only use two cpu fans on the cable, as i dont see the point of buying expensive PWM fans to use as case fans.
