Different brand but same speed RAM in laptop - Only single channel
12 Dec 2005
I added an 8GB 3200Mhz DDR4 RAM module along side the current 8GB 3200Mhz DDR4 RAM module in my laptop, they are different brands though. From what I read online before hand different branded RAM should still run as dual channel as long as the speed is the same however that's not the case for me since CPU-z says the RAM is running in single channel mode
Can anyone shed some light on this for me please?
Cheers
Your laptop only has two slots, right?
What else is different between the sticks?
It could just be a misread from cpu-z.
The laptop only has 2 slots
This is the stick that I added today
This is the stick that came with the laptop
Apparently I'm told that 2 x 64bit indicates dual channel mode so I think all is good :D
DDR memory is 'double pumped' :p
So it is reading correct. DDR = Double data rate. Whatever you see in cpu-z times it by 2. Is it still saying single channel though? Maybe different timings and different voltage between the two sticks not playing well together?
Is this something I should be concerned about/try to fix ?
If you have the option to change memclock=uclk in your bios to 1:1 then change it, if not then dont worry about it, you will find that in CPU-Z screenshot they will both read 1594mhz (1600mhz), regardless of your ram doubling up the data rate (DDR double data rate), not the frequency, DDR and frequency are 2 different things.
Your RAM speed to 1594mhz (1600mhz), which makes your Date Rate 3188 (3200MT/s) but your uncore is 796mhz half of your ram speed, this puts you in 2:1 mode, this is 1 cycle of your ram for every 2 cycles of your memory controller.
This is what 1:1 looks like, and even if you do double up my ram speed to 6400MT/s (DDR) its still 1:1 because the true frequency is still 3200mhz, its the data transfer rate that changes / doubles, (MHz vs MT/s Megatransfers)
