- 29 Dec 2005
been doing some testing on my cpu this morning
core 0 doesnt overclock as good as core 1, since they are gonna be made from the same piece of silcone it doesnt make sense that they should vary largly.
so i can a couple of prime tests
room temp 29c
started off at [email protected]
cpu idle 32c
core 0 load 35c
core 1 load 34c
i did this test 3 times to make sure it was correct.
its only 1c difference but that does get larger the higher the voltage is.
the only thing i can think of is that the compound on the core is better on core 1 than core 0 and if i delid the chip it will even out.
your thoughts, comments please
room temp 29c
cpu idle 32c
core 0 load 35c
core 1 load 34c
