Just had a read throught the last few pages of threads and it would seem that having dual cores reading different temps at idle is normal/common. I have just got an E8500 with an AC freezer and the temps are over 10 degrees apart at idle however as soon as you start orthos up they level out, both at about 60. Is the temp difference anything that can be sorted? Is it worth applying a bit of arctic silver and refittting the HSF? Should it be sent back?
Cheers
Dave
Cheers
Dave
