Different fan speeds on sli cards
Caporegime
14 Dec 2005
armoy, n. ireland
Just noticed that on my two gpu's, the fan speed on one card is always a bit higher than the other. Im using auto fan through msi afterburner, (40% at idle), id have thought both would run at the same speed?
Gpuz sensor ss.
Why are u surprised by this setter?
My top 470 runs hotter therefore the fan runs quicker?
Same like everyones SLI setup. (excelt water cooling )...
Right I get u now....
"I set auto fan at 40%" threw me off.
Yes they should be the same speed. But I would hazard a guess the top card which has less room and space runs slower and bottom runs quicker?
Err the one with the faster fan speed is running cooler than the one with the slower fan speed. And auto fan will not kick in until temps reach 60c or there abouts.
Going by afterburner, assuming that gpu 1 is the topmost card, currently idling at 31c, fan at 1770 rpm, gpu 2 bottom card, currently at 30c, 2100 rpm. I know that in sli the topmost card usually runs a bit hotter, though i do have a 120mm fan behind the cards.
Dude u got afterburner? It's got a tach reader too u know ;-9
Screenshot of afterburner monitoring panel.
I can only assume that airflow must be ok as the topmost card is running the slower fan speed, albeit 1c higher, quite used to my previous sli setups having a rather higher temp top card.
