Different memory, would these work together?
27 May 2007
Front of the monitor
G'day OcUK memory specialists!
I have 2x1GB OCZ PC2-6400C4 Dual Channel Platinum Revision 2 XTC in my PC and thinking of buying another pair of 2x1GB memory but not sure if they are compatible together.
The memory that I am looking at is Team XTreem 6400 3-3-4-8 DDR2 RAM 2x1GB.. I have tried google but not much success.. might be that I am using the wrong search words so thought I would ask you guys here! Also, would these be compatible with my motherboard, its a Gigabyte GA_P35C_DS3R? Don't really want to buy them and then they wont work together! :eek: Ohh not sure but just incase.. I am not going to overclock them, just using them on stock settings..
I appreciate your assistant! :D
they will probably work together, but will work at the speed of the sloest sticks. Without actualyl trying them ther eis no 100% answer though. I would jsut buy the same RAM again.
They should work, but the sticks will run at the speed of the slowest stick, if that makes sense. So probably will be fine at PC2 6400. However, it is always safest if you can get the same sticks again.
