Different refresh rates on diff outputs?
26 May 2009
Hey guys, I currently have a Dell U2913WM monitor (2560x1080, IPS, 21:9) running at 75Hz via one of the display ports on my GTX970. What I am wondering is, can I connect a second monitor to another output and run that at a different refresh? it would be an old 1280x1024 screen running at 60Hz proberbly connected via DVI.
Yes, I've had a 144hz 1080p monitor running next to a 60hz crap monitor. You just change the settings in windows :)
Just when you drag a program across it will go from nice and smooth to horrible and jumpy.. Well mine did!
Yes this is no problem. Only if you were trying to duplicate the displays would you have a problem and have to run them at the same resolution and refresh rate.
