Different resolution multi monitor setup
10 Jan 2013
Currently im waiting on delivery of an LGUM68 34" ultrawide, and ive got a 24" Iiyama im going to be running portrait on the right hand side of it, and was planning on adding a second to the left.
Just came into a little bit more money and im really tempted to cancel the order of the LG 34" and get a 34" of higher quality/resolution, but would it be weird having a 1440p/4k monitor in the middle and it being framed by two portrait 1080p monitors at the ends?
I used to run three slightly mismatched screens - 1920x1200 in the middle with 1920x1080 on each side.
Whether it's weird or not is pretty much down to you and your plans for using it. If you're looking at merging them into one big screen as far as Windows is concerned (Eyefinity on AMD, or Surround on Nvidia) and gaming across them, that might be problematic due to the different resolutions depending on how you have it set up (bits off screen top and bottom above the middle screen, or blank bits top and bottom of the side ones, etc). If you have them as three separate screens then the only issue I ever had was when moving the mouse or a window from one screen to another, it would move from the bottom of one screen and appear not quite at the bottom of the next one as that was running a high resolution. Got used to it in the end, but drove me nuts for a while.
Best suggestion as you have the monitor on it's way is to try it out and see how you get on with it after a day or two. You can then return or buy if you want to, or stick with what you have - your choice.
