- 17 Sep 2012
- Derby
I have 8 compression fittings using 1/2" tubing, i want to add some other bits and bobs to my machine soon, the only fittings i have knocking around are 9 compression fittings that would use 7/16ths tubing
i was thinking of using 8 of the 7/16ths and then just using 2 or 4 of the 1/2" ones.
would this be ok or would the flow rate be different or anything?
