different types of geforce cards?
if im correct i think its LE, GS, GS-T, GT, GTX and then there are XXX derivatives of some of the above
cheers
Ben
not much - a GS is a GTX that was not fit to be sold as a GTX so bits have been chopped off and what not - i think
so basically a GS is a cut away verstion of GT/GTO/GTX etc and there for is slower
okay in that case, whats preferable out of:
-Leadtek GeForce 7600 GT 256MB SILENT Heatpipe GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
-Leadtek GeForce 7900 GS 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
you could try typing in google eg "7900gs review" or whatever cards you are intrested in this will explain the diffrences between cards
basicly the dearer the better is how it usualy goes with some exceptions like the 7900gto
Nvidia: LE, GS, GS+ (rare), GT, Ultra, GTS, GTO (rare), GTX
ATi: SE, <nothing>, GT, Pro, XT, XT-PE (rare), XT-X
Warnings:-
NVidia cards (a) with an 'FX' in there somewhere or (b) with a '2'! (e.g. FX5200)
ATi cards (a) with a number '6' or lower, without a '9' (e.g. x1300, x1650) or (b) that sound similar to a good card (e.g. 9550 sounds like 9500 Pro)
