Difficult to engage 1st gear when very cold?
Man of Honour
17 Oct 2002
Retired Don
Hi guys, I've noticed in my BMW E46 that when it is very cold, it is quite difficult to engage 1st gear, until I've been driving for a good 15 mins or so.
Is this an indication of something wrong, or is it normal?
Thanks,
Mal
Every manual BMW I have ever driven has been like this to be fair. Not usually a problem unless it starts doing it in more gears or when its hot.
Same as mine - has been like it since I got the car. I found that a gearbox fluid change (£45) helped a bit.
Tends to be easier to get in if you slot it into 2nd, then first.
My car has been doing this recently too, 1st to 2nd can feel a little rough also. I think it's just the transmission fluid going a little buttery due to it being so cold out.
My car is a PITA to change to second at the best of times when cold. This weather only makes it worse.
