Difficulty installing themes
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
Just trying to learn how to properly install themes in OpenSuse, problem is, I can get a theme where the menu bar at the bottom and the menu that pops up has changed, but the window borders with the minimise buttons on and other things are still the ugly defaults and not what the theme shows.
Any ideas how to change it?
Thanks
Will.
Are you changing it in System > preferences > appearance?
Also consider that a lot of fancy themes will also need fancy engines installed.
What theme are you trying to get working?
I get it via:
System, look & Feel, Appearance, then in Windows, Window decoration, there is no theme to choose that corresponds to the theme I downloaded :confused:
That does not really help, it appears it's very different from 2006 Ubuntu, I'm using the latest version of OpenSUSE and it appears slightly diffo.
