Ok this is a bit of a long one. I am helping a lecturer in my work get a suitable setup for a digital audio workstation/recording studio.
Here is his email to me...
"What I’m looking for is an audio interface for digital recording with a DAW (Digital Audio Workstation).
My software (DAW) is called Reaper, which has a great forum where people discuss what works best for them: https://forum.cockos.com/forumdisplay.php?f=20
Some units that I’ve considered are listed below, but they all tend to be USB 2. And I kinda feel there’s no point buying USB 2 if new units are going to appear soon with TB3. (Oh, and I just avoid the Focusrite and Akai brands altogether – they have a terrible reputation for cheapness, crashing, etc.). Mulitple outs for monitoring would be helpful….
I've put the music hardware links in spoilers as I think they are ok to quote but if not please tell me and I'll remove them. I don't think OCUK sells this sort of audio stuff.
I'm happy enough to build him a PC that will power the above and do the processing of the raw musical data but I'm not sure what is the best route for him to take. Obviously he's going to be spending a fair whack of cash on the entire setup and I don't want to throw him ideas that won't work.
Anyone that knows anything about sound recording etc, looking at the above links what would you suggest that he should be looking to get in terms of the actual AUDIO INTERFACE? Is there a good brand/model that he can get? He wants to be able to use Thunderbolt 3 (TB3) for bandwidth and I will be looking for a motherboard that supports TB3 use.
Does anyone have a music recording setup that they can give me some advice on? It's quite specific so someone with knowledge, I would be really grateful for some help.
