Digital camera ... £130 ish??
7 Jul 2004
Gloucester
Hi
I'm looking for a digital camera, the best I can get for about £130ish. The cheaper the better but £130ish is the max I can go to. I've been looking at the Samsung L60, what do you guys recommend? :confused:
Ok, that one looks good etc.
Now I cant decide between the canon A540 & the samsung L60 :confused:
Samsung pros:
Longer battery life
Video filmed in mpeg 4
I trust samsung
Samsung cons:
Would need to buy special spare battery
Not sure on IQ?
Canon pros:
AA batterys mean I can use any as spares
I know they have good IQ
4x zoom (over the 3x offered by samsung)
Canon cons:
Batteries dont last as long
Video is filmed in a way that means you cant film for long
I'm swaying towards the samsung but I am really stuck, i'd like to get it today really. Which do you think? :confused:
would recommend popping over to Amazon.co.uk, and searching for it. You can put in price first between £100-£200 then filter down by make and amount of megapixels.
For example:
Clicky
The reviews of the S700 are really bad though, it was what I was originally going to go for. Apparently the picture quality is worse then a lot of 5MP cameras.
I went for the Samsung L60 in the end.
I went into a shop & it was more comfy to hold then the canon. Also the XviD video recording & flat lithium long life battery won it for me. Was cheaper in a highstreet store then anywhere on the web too :)
